About Queries with External Files
939
02-05-2014 07:12 AM
EvelynHernandez
Hello. I hope somebody help me.
I need to know how to get some IDs from an external file(txt, excel, etc) and make that the service do it and then put the graphics  on the map.
Im just starting programming flex with arcgis and really i dont know.
Thanks for ur patience guys 🙂
AnthonyGiles
Honored Contributor
Evelyn,
I have a widget for the viewer that does that:
http://www.arcgis.com/home/item.html?id=cdac64f40b53435c9b191731fcd3c9c1
You maybe able to adapt the code I'm using to suit your needs.
Regards
Anthony
AnthonyGiles
Honored Contributor
Evelyn,
Regards
Anthony
EvelynHernandez
Thanks for ur help (:
The widget works but i still need that the service reads and load the file automatically.
Im not using widgets, just programming in flash builder T-T
The thing that i need to do is with a QUERY gets the ids from an external file given and then that query associated to a service, to put the result in a map.
