3 QUESTIONS ON FLEX
835
03-11-2013 12:39 AM
SaniTakwim
Dear All,
I'm using ArcGIS Server 10.01 with Flex as the design for our Application.
My 3 questions :
i) "Zoom to scale" - when I type 1: 10,000 or 5,000 or whatever else, it zooms to a different scale everytime. Is there a fix for this?
ii)I would like to save permanently whatever points or markings which I'd done on the view i.e. everytime I open the application, they will always be there. Is this possible?
iii)How do I make a print layout that can be saved as pdf?
Your early assistance are very much appreciated. TQ
AnthonyGiles
Honored Contributor
Sani,
Are you talking about setting the scale in the map tag of the config I.e. scale="5000". If so and you are using a tiled map service the scale must match one of your cached scales. These can be found by looking at the rest endpoint for the service:
http://services.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer
You could do ths by either setting up some editable feature layers:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Tutorial_Performing_web_editing_using_data...
Or by Roberts enhanced draw widget that allows you to load pre saved graphics from a file via the URL:
http://www.arcgis.com/home/item.html?id=91a0014160fc4a9caadc2c7fd7089c1b
http://resources.arcgis.com/en/help/main/10.1/index.html#/Tutorial_Publishing_additional_services_fo...
Regards
Anthony
