2 Editors one map
1164
06-26-2012 07:59 AM
SachaTousignant
Hey,
I've been working on my flex app and I'm trying to resolve the following problem :
I have 2 widgets, they both have one editor in them and whenever I open either one and open the 2nd one, then it crashed with the following error message :
TypeError: Error #1034: Failure of the type constraint: conversion from com.esri.ags.components::TemplatePicker@c5550b1 to com.esri.ags.components.TemplatePicker impossible.
I tried to use my own skin for both of my editors, one skin per editor ( I took the skin from the api and only renamed it). Same problem but the error message is different : TypeError: Error #1009: Cannot access a property or method of a null object reference.
I also tried to catch the event when I get the error messages but it doesn't work either. I used :
<esri:Editor id="editorFatalities"
         geometryService="{myGeometryService}"
         map="{map}"
         featureLayers="{[incidentsPoints]}"
         toolbarVisible="true"
         skinClass="com.esri.solutions.flexviewer.themes.surete.AccidentsEditorSkin"
         fault="editor_OnFault(event)"/>
I could have throw an alert and tell the user to shut the other widget..
Any help would be really appreciated since I got no other ideas what to do with this.
SachaTousignant
I tried a different approach, instead of using editors, I tried to use templatepicker as this sample recommands : http://resources.arcgis.com/en/help/flex-api/samples/index.html#//01nq00000043000000
But, I just noticed that the same problem is happening, once I open one of my widget, when I try to open the other one, it crashes. Even with 2 differents skinclass. So, does it mean it is not possible to have 2 editors or 2 templatepickers at the same time open or there's a workaround?
Thx alot!
SachaTousignant
Still need help, can someone from Esri answer this?
I had the idea for now to program my own templatepickers, images with events on click and all.
But I'd really appreciated to know if it's possible to have 2 templatepickers, one in each widget in my case.
Ty
