Arc GIS map in power bi
1047
01-30-2024 11:49 PM
Sarahsal
Hello All,
Just wanted to check if anyone can provide some guidance regarding following issue.
We have data at ward level (UK) which has Ward name, Latitude, Longitude & numerical columns for heat map.
But when we try to create map based on ward name, we don’t get option for Ward in Location type.
tried all the existing options from location type. it doesn’t map properly as expected.  (example in attached screen-print).
could someone please suggest which option to use Location type dropdown to correctly map ward data or some other options / settings in ArcGIS.Arc GIS.png
