ESRI Basemaps slow to load and redraw in ArcMap 10.3
16940
11
07-26-2017 05:37 PM
HeatherSavage
Users that I work with are having problems using ESRI's ArcOnline Basemaps (specifically World Imagery Basemap) because the load and redraw rates are very slow.  I have had them switch to the same coordinate system as the basemap (WGS 1984 Web Mercator, Auxiliary Sphere) and this usually resolves the problem.  However, most of our working data is in Alaska Albers Equal Area Conic, and some users find WGS 1984 difficult to deal with in very high latitude areas (north slope) due to distortion.  Are there any other suggested solutions for speeding up redraw rates?
Tags (1)
HeatherSavage
Thanks, Ryan.  This tip was very helpful.  It's still not as fast as using WGS1984, but it is a big improvement and an easy adjustment for users to make.
Most of our users have not switched to Pro yet, but I did notice that rendering is much faster in Pro (2.0) than in ArcMap, even when using Albers.
AndresCastillo
Thank you for contributing this valuable feedback
