point
1150
04-12-2018 06:47 AM
GERTISEDO
Hello
I have problem with import this table with coordinate on utm  on gis 10.4.1 could someone what can
import for please attach material
DanPatterson_Retired
Try adding a header
ID, Northing, Easting, SomeNum, SomeTxt
Then when you have it in, make sure you define its coordinate system
GERTISEDO
i have done this  and its ok but when i  try connected  this with WMS i have problem
you really need to elaborate on exactly where you are doing this.
if this is a web thing, then utm is generally not a supported on the fly coordinate system, especially since there are 120 utm zones and the csv file doesn't provide information on where in the world it is, so it will undoubtedly fail.
If this isn't being used in arcmap or ArcGIS pro, then that form of csv is pretty well useless without being converted to a form that its coordinate system can be defined while bringing it in
