Integration ProjectWise - ArcGIS Enterprise or ArcGIS Online
3769
03-25-2021 10:07 AM
Diego_Mendes_Rodrigues
I have a sales opportunity in a company that uses Bentley software.
The project management software used is ProjectWise.
In the ProjectWise documentation I see the integration with Esri's server software using ArcSDE.
Is there an integration with ArcGIS Enterprise?
Is there an integration with ArcGIS Online? The customer prefers to use a SaaS solution.
If the integration exists, what can be done in this integration?
I would be gratfull for any feeback or advice.
ProjectWise Connector for ArcGIS Help
https://docs.bentley.com/LiveContent/web/ProjectWise%20Connector%20for%20ArcGIS%20Help-v1/en/GUID-28...
https://docs.bentley.com/LiveContent/web/ProjectWise%20Geospatial%20Management%20Explorer%20Help-v2/...
Regards,
Diego M. Rodrigues
Prezados,
Tenho uma oportunidade de venda em uma empresa que utiliza softwares da Bentley.
O software para a gestão de projetos utilizado é o ProjectWise.
Na documentação do ProjectWise vejo a integração com os softwares servidores da Esri utilizando o ArcSDE.
Existe uma integração com o ArcGIS Enterprise?
Existe uma integração com o ArcGIS Online? O cliente prefere utilizar uma solução SaaS.
Caso a integração exista, o que pode ser realizado nessa integração?
Atenciosamente,
Diego M. Rodrigues
DanielChantlos-Esri
Hi Diego,
Currently, there is not an active plan on our roadmap for an ArcGIS Pro integration with ProjectWise. We are aware that there was an old connector created by Bentley for ArcGIS Desktop, but that tool has not been updated in a long time. We would consider a ProjectWise connection in the future, but we would need to get more details on what specific connections and workflows are needed. ArcGIS Pro currently supports .DGN files, but please reach out if you would like to meet and discuss more about the current needs for a ProjectWise connection.
However, due to our partnership with Autodesk, our focus has been integrating ArcGIS Pro with Autodesk Construction Cloud (BIM 360) for a similar purpose. You can read more information on how to establish a connection here: How to Connect ArcGIS Pro to Autodesk BIM 360
Daniel
DanielChantlos-Esri
Hi Diego,
Daniel
