I am not able to see my created Las-Dataset File?
2881
14
10-12-2018 02:33 AM
tobiashog
Hey there,
I created a LAS-Dataset File with my LAS Input Data. I runned it succesfully. But if I want to see the Data in the Scene there is no data. Can someone help me?
George_Thompson
Esri Notable Contributor
When you are working with the LAS Dataset in the 2D map do you see the red boxes?
If you do, do you see the points once you zoom in?
Also check the properties of the LAS Dataset. Do you see something like this?
--- George T.
tobiashog
there is nothing at all. I cant see the red box and the points. The properties are like this:
Do you have a solution for my problem?
George_Thompson
Can you just add the LAS file in Pro to a 2D map and see it?
I also noticed that you LAS is not classified in to the codes?
--- George T.
tobiashog
i cant even add the LAS file into a 2D map.
File-Upload.net - alterFriedhof.las
I uploaded my LAS-File now. Maybe the data is damaged or something like this?
George_Thompson
If you cannot see anything in a 2D map, the LAS file may be bad.
I would ask the vendor/supplier of the LAS file about it.
--- George T.
tobiashog
Is there a possibility for you to check my data? Maybe the problem is me and not the data by itself?
Thank you for your help.
George_Thompson
I am unable to access it. Do you have a link to the source data?
--- George T.
tobiashog
Is this Link working: https://ufile.io/uzdj0 ?
I know, I'm replying to a very old thread. But I'm currently in the exact situation you described: I can see my  las data (a mobile mapping point cloud) in 2D Maps, can't display them in 3D Scenes. Property and datum of the datasets seems ok.
Where did I go wrong?
