How to delete Polygons within a bigger polygon?
10350
11
07-30-2018 09:49 AM
NataliaGutierrez2
I am working with a parcel shapefile of an entire state. I need to remove all of the building polygons falling inside the bigger parcel polygon. These are not donut holes but instead separate polygons.
I can't erase each polygon manually because I am working with the entire state dataset.
What geoprocessing tool should I use?
I have attached an image below:
Thank you!
Tags (1)
NataliaGutierrez2
Dan thank you for your help.
I was able to use 'Completely Within" by duplicating the feature class since this tool only works with two feature classes.
This was the problem I was having.
DanPatterson_Retired
Yes, as in my initial response, you need to use the same file for both inputs.
