How can you tell if a Geodatabase has true or segmented curves?
866
02-01-2022 02:54 AM
ChrisBaze
I am trying to determine if the Geodatabase file available at https://honolulu-cchnl.opendata.arcgis.com/datasets/cchnl::parcels-regulatory/about has true or segmented curves for the parcels. Every way I try to import this to Autodesk software results in segmented curves and I do not have access to ESRI products. What is the easiest way to check?
DanPatterson
Polyline—ArcGIS Pro | Documentation
a Field Calculator expression
hasCurves
(Read Only)
Returns True if the geometry has a curve.
For a text field
str(!Shape!.hasCurves)  # -- to see False, True
... sort of retired...
Stefan_Thorn
Occasional Contributor II
@ChrisBaze, maybe you already know? But the curves are segmented in the data.
