ArcGIS Online Assistant Map Services
5126
03-02-2015 04:23 PM
HerveyLee
I am trying to update my URL with github.com for a web map from a feature services to hosted services.  The URL are coming from 2 different domains.  The layer does not show on the web map if I attempt this task.  Is there a way to update the URL without having to remove and added back into the web map?
NeillJobe
It seems as though you're talking about the AGO Assistant Tool. This Page is for the Admin Tools for ArcGIS Online application.
You can get the Admin Tools for ArcGIS Online & Portal on the ArcGIS Marketplace here
Neill
TobiasFimpel1
Not sure if I fully understand wat you need to accomplish, but did you try this yet: ArcGIS Online Assistant . It allows you to edit the url's of webmap-layers in json format.
NeillJobe
Neill
