Suggestions from locator
1047
11-22-2019 11:16 AM
JoeBorgione
ArcGIS Pro 2.4.0
In Scoring options with Create Locator  we discussed changing properties of the new style locators.  Having gone in to Properties pane for a new locator and made some adjustments, I'm still a little fuzzy as to what's going on.
The locator itself is a single role street address with alternate names.Using the locate tool interactively it appears to be working as designed: here are the properties as I've set them:
However, when I enter an address that I know is way out of range, I get a suggestion of just the street name:
And the 'A' location is located along a segment of S State St with a range of 6790-6849.
How do I suppress this type of suggestion? Is it possible to get a return of 'Address Not Found'?
What's the deal with the arbitrary location of the suggested address?  Just curious about that...
Brad Niemand
That should just about do it....
Tags (1)
JoeBorgione
Suppressing the suggested street name as a return is controlled here:
