Shana,
Correct, I am creating two separate locators and adding them to a composite. Unfortunately combining them into a multirole locator does not seem to work because even though I enter the address points above the roads that hierarchy does not persist in the results. So, there could be a match in my address points that has a score of 91 and a match from my roads input that gets a score of 96. Ideally I want any match from the address points over 85 to be returned even though the score is lower than the match from the roads. Perhaps I am missing something but I only see a way to set score thresholds for all roles collectively rather than on individual roles to prevent this from happening.
Both of my locators have an alternate city name table and an alternate street name table. I have tried tweaking the settings provided in the performance documentation and they don’t seem to speed up batch performance. There is an id that links the address points to the street centerlines, how can I use that my advantage?
Thank you so much for your help!
