Geocoding and getting uniquefeatures
1764
12-16-2019 07:36 AM
LisaSwarn
Good Morning,
I managed to geocode a CSV and everything matched.
My problem?
There are 10 projects within the attribute table but only 5 dots are showing up. This is because some of the projects happened at the same address.
I would like to make each project its own unique point.
How can I go about doing this?
JoeBorgione
They are unique points.  The problem is they are 'stacked' on top of one another so they 'look' like one.  The only thing I can think of off hand is to move them in an edit session so they aren't coincident. You only have a few, so it won't be so bad.  If you had dozens, or hundreds or more, then you'd probably want to come up with some kind of automated solution.
That should just about do it....
JoeBorgione
LisaSwarn
Thank you!!!
As I was editing, I realized I could just move them!! Thank you!!
LisaSwarn
If it was more, you are right, there would need to be some more thought.
