Populate a Field with consecutive numbers in Field Calculator
4749
07-27-2017 09:53 AM
CommonUser
How do you populate a Field with consecutive numbers in the field calculator ?
BrianCarson2
Hello Randy,
The following Field Calculator expression (which must be used with the Python Parser), will auto increment a numeric field. We can modify the pStart = 1 and pInterval = 1 parameters to control the starting number as well as how much it will increment by.
Pre-Logic Script Code:
global rec
rec=0
def autoIncrement():
  global rec
  pStart = 1
  pInterval = 1
  if (rec == 0):
    rec = pStart
  else:
    rec += pInterval
  return rec
<FieldName> =
autoIncrement()
Best,
Brian
CommonUser
Awesome!! Thanks
Thank You,
Randy Hill
GIS Analyst II
City Of Newnan
25 Lagrange St.
Newnan, Georgia 30263
(678)673-5503
