My Arctoolbox tools are still not working after I reset my application, what should I do?
1183
04-23-2020 03:57 PM
AvaSamuels
I keep trying to use the project tool under Data Management, and the Conversion tool.
All my tools don't work when I use them though.
After inputting the correct fields for Project tool and pressing OK, the map loads and then nothing happens or changes
and when I quit out of Arcmap, it gives me a message saying that geoprocessing is still working, but I've waited for more than an hour and nothing happens.
I've tried this multiple times and I can't figure it out!
I even tried resetting the app by renaming normal.mxt
Lmk if you have suggestions, I need this to work for my GIS class labs.
My ArcMap version is 10.7.1
DanPatterson_Retired
Windows Start, Add/Remove program, Choose Remove, then you will be given the option to Repair the install.  do that
