Knowing pixel values
826
6
11-29-2017 10:00 AM
Mariam_Salem
I have a large raster layer that has aridity values assigned to each pixel. I also have latitude and longitude data of some locations in USA. I would like to know the pixel value according to my latitude and longitude locations . I first clipped the raster to my area of interest (USA) in Arcmap the I converted my clipped raster in to a .tif file. I don't know how to extract the pixel values according to the locations that I have. I tried a few things but it either doesn't work or I don't have the license (such as for extract).
Thank You for your help^^
I have attached an image of what I have.
DanPatterson_Retired
Extract Values to Points or its brethren Extract MultiValues to Points IF you have the spatial analyst extension
Mariam_Salem
Hello Dan thank you for your reply^^
I unfortunately don't have the spatial analyst extension, is there a way around this?
There is... but it requires programming in python and numpy... sorry... so short of  the info tool, you are a bit stuck
Mariam_Salem
It's alright^^
Again thank you Dan
XanderBakker
Esri Esteemed Contributor
Here is a document that could get you started, but you will have to program using Python: https://community.esri.com/docs/DOC-2954
Mariam_Salem
I will have a look at it^^
Thank You Xander
