If I have two point feature classes and I would like to measure the distance between those two points (or to the next point), what tool would be best to use to measure those points?
2091
7
08-09-2018 12:01 PM
by Anonymous User
Not applicable
Would like to find the distance of one point to the next closet point.
DanPatterson_Retired
License level?
Software
Near—Help | ArcGIS Desktop
Generate Near Table—Help | ArcGIS Desktop
plus other potential solutions depending on what you have and are using
by Anonymous User
Not applicable
Advanced, ArcMap 10.5.1.
then you should be good... did you given them a try?
by Anonymous User
Not applicable
Yes and it worked.  Thank you.
Isaiah, you should close the thread as answered so that people know a solution was found.
by Anonymous User
Not applicable
Hey Dan,
Could you also help me out by telling me how to mark it as such?  This is my 1st time using GeoNet.
Isaiah, you can't actually mark it Answered when you respond to a thread in your 'mail'.  You have to click on the title of the thread, and you should see something like "correct Answer' or something to the right of the thread that provided the answer.
You should have a run through
GeoNet Tools Resources hub
That particular task is outlined here https://community.esri.com/docs/DOC-2159-mark-a-reply-as-the-correct-answer
Have fun
