coordinate system in Honduras
5975
05-01-2016 03:45 PM
RamonAntunez
What's the coordinate system used in Honduras, along with it's Geoid model?
DanPatterson_Retired
from this site, EPSG Geodetic Parameter Registry type Honduras in the area box, you should get a listing of unprojected and projected coordinate systems with datums, geographic transformations etc.  There isn't just 1 that is used, so you may need to clarify
AdrianWelsh
MVP Honored Contributor
Hi Ramon,
Like Dan said, there are quite a bit. The site he posted gives you quite a few systems you can use when you type in Honduras. If you click on the 'view' button next to each one, it gives you more details, like the ellipsoid model.
NameCodeTypeStatusArea DescriptionRemarks / Description
ITRF2014
EPSG::7789
GeodeticCRS (geocentric)
Valid
World: Afghanistan, Albania, Algeria, American Samoa, Andorra, Angola, Anguilla, Antarctica, Antigua and Barbuda, Argentina, Armenia, Aruba, Australia, Austria, Azerbaijan, Bahamas, Bahrain, Banglades...
Replaces ITRF2008 (CRS code 5332).
view
NAD27
EPSG::4267
GeodeticCRS (geographic 2D)
Valid
North and central America: Antigua and Barbuda. Bahamas. Belize. British Virgin Islands. Canada - Alberta; British Columbia; Manitoba; New Brunswick; Newfoundland and Labrador; Northwest Territories; ...
Note: this CRS includes longitudes which are POSITIVE EAST. Replaced by NAD27(76) (code 4608) in Ontario, CGQ77 (code 4609) in Quebec, Mexican Datum of 1993 (code 4483) in Mexico, NAD83 (code 4279) i...
view
NAD27 / UTM zone 16N
EPSG::26716
ProjectedCRS
Valid
North America - between 90°W and 84°W. Belize. Canada - Manitoba; Nunavut; Ontario. Costa Rica. Cuba. El Salvador. Guatemala. Honduras. Mexico. Nicaragua. United States (USA) - Alabama; Arkansas; Flor...
Replaced by NAD27(76) / UTM 16N (code 2028) in Ontario, by NAD83 / UTM 16N (code 26916) elsewhere in Canada and USA, and by Mexican Datum of 1993 / UTM 16N (code 4489) in Mexico. See NAD27 / BLM 16N (...
NeilAyres
And if you want all the history of survey in Honduras, se Clifford Mugnier's Grids & Datums from ASPRS.
