base map
2395
6
07-18-2018 06:24 AM
HenryWanjala
I used the add data button once to add a basemap. i must have faulted with something along the way because since then i haven't been able to do that again. When I click the add data menu, the 'add basemap' option is not selectable same as the online basemaps
BrianBaldwin
  • If you are in ArcMap, go to File, Add Data, Add Basemap
  • In Pro, go to Map tab, Basemap
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
HenryWanjala
Thanks. That is what i keep doing. But the option to add basemap is greyed out. It cannot be selected so is the online resources option.
HenryWanjala
This goes on in new map documents so that I can no longer choose a basemap
BrianBaldwin
 What version of ArcMap? Does the client have an internet connection?
ChrisDonohue__GISP
Besides what BBaldwin-esristaff suggested, do you have an ArcGIS Online Account?  Maybe the account is not working?
Chris Donohue, GISP
rachelg_esri
Hello Henry,
I would recommend taking a close review of the following link with your IT department. This should help you narrow down where the issue lies.
https://community.esri.com/groups/technical-support/blog/2013/04/01/having-issues-adding-arcgis-onli...
If you still can't add basemaps after a thorough review of that article, feel free to give us a call at Esri Support to log a case - we can take a look with you!
Rachel Guttmacher
ArcGIS Online Technology Lead
Esri Support Services
