911 address point file...?
6355
02-10-2015 08:39 AM
DewaineHobby
where can I find out what fields are needed for a 911 address point file...?
I have a shp file of the centerlines with the streets, from right to right from left.....ect..
wanting put point where building is located and when 911 call comes in display map
zooms to location....
Thanks in advance...
learning something new everyday... 🙂
TimWitt2
Hey Dewaine,
It usually depends on what kind of mapping software your dispatch center is using.
This might be helpful https://www.nena.org/?page=gisdatacollection
On the first page in this article you can see what fields we have for our addresspoints:
http://www.esri.com/esri-news/arcuser/fall-2013/~/media/Files/Pdfs/news/arcuser/1013/attribute.pdf
Hope this helps!
Tim
DewaineHobby
Thanks I'll got check these out, the dispatch is using InterAct software
Thanks....
TimWitt2
Dewaine,
We were using InterAct before we switch to a different company. My fields that you see in my article, are the fields that we used in InterAct
Tim
JoeBorgione
Tim- what cad are you migrating to?
That should just about do it....
TimWitt2
Joe,
we only changed mapping software. There are different CADs in our county for example New World or Tiburon.
Tim
