Working in ERDAS
4891
7
08-17-2015 02:52 PM
Kofi_Lartey
I clipped some rasters in arcmap 10.1 and wanted to continue working with it in erdas 2010 but its not working, how do i get over this please
DanPatterson_Retired
Are you using this?  Overview  if so, then they may have support for their product
JayantaPoddar
Hi Kofi,
Try saving the output clip image in .img or .tif format.
Think Location
Kofi_Lartey
They were in .img format. Interestingly when i opened in erdas 2013 it opened and i have started work on them. But i am still wondering why it will not open in 2010 as i even used the import tool to change the format in 2010. Any ideas?
​You should report the issue to both software companies
Kofi_Lartey
Thanks Dan, will try.
Finally what i did was to open the output in arcmap and export them in Tiff format before i could open them in ERDAS. Thanks
Kofi_Lartey
As a  follow up, i am trying to extract features from the clipped orthophotos in erdas using the imagine objective. I am working with the erdas 2013 version but dont seem to find the objective tool bar. I have tried various means but still not successful. How do i locate and activate the imagine objective in erdas imagine 2013.
XanderBakker
Esri Esteemed Contributor
This second question is the type of question you should ask in a ERDAS forum not in GeoNet which is for ArcGIS related issues.
