Visualize LAS dataset with RGB is not working?
3059
08-09-2011 12:20 PM
XanderBakker
Esri Esteemed Contributor
I created a LAS dataset from a single LAS file. When calculating the statistics of the LAS dataset, it shows that I have RGB attributes:
Red Attributes 0 255
Green Attributes 0 243
Blue Attributes 0 228
When I want to visualize the data using the RGB values this option is grayed out (see attachment).
The dataset used was retrieved from the following website:
http://liblas.org/samples/ (xyzrgb_manuscript.las)
Any suggestions?
Tags (1)
JorisBak
Xander,
RGB is only supported in 3D, so try it with ArcScene.
XanderBakker
Xander,
Thanx, Joris. That did the trick!
