Visibility analysis with real 3D data (multipatch or KML)
1116
10-04-2010 05:34 AM
AlzbetaBrychtova
Hi all,
I was looking forward to the new ArcGIS because I hoped that the possibility of the visibility analysis will be finally implemented.
Unfortunately, this did not happen, so I'm looking for another solution, which could calculate the 3D analysis visibility with data type multipatch or KML.
I dont want to burn multipatch to grid. I really want to have result of real 3D data.
Any suggestion?
Gert_van_Maren
Esri Alum
What exactly do you mean with 3D visibility analysis? The LOS tool in 3DA now supports multipatches so you do not need to burn multipatches into the DEM.
Also if you are after a 3D viewshed analysis: this is also now possible. Have a look at our new 3DGIS resource center in the video section.
http://resources.arcgis.com/content/3dgis/10.0/about
Gert
