Using LAS 1.2 specification data in 9.3
1353
10-01-2010 12:47 PM
FelipeAvila
3D analyst for 9.3 does not seem to support LAS 1.2 spec data when trying to convert a LAS file to a multipoint feature.  Is there a work around for this or can Arc 10 handle this format?
Tags (1)
MohammadDashti
another way to inport .las file is to convert it to .txt file.
I use lastools, open source tool available online.
convert las to txt extracting x,y,z and other data you need in .csv format
then add a header using txt editor e.g. x,y,z,i
import .txt file to arcgis
plot x y point
export data and save as .shp
for large file importing and savisng in arcgis might take some time
Regards,
JakubSisak
Honored Contributor
Check out the 3-part ESRI blog on this topic:
Part1 Part2 Part3
