Sun shadow volume
6562
11-17-2013 11:15 PM
Patrickvan_den_Ende
I was wondering if it is possible to get information out of a sun shadow volume? I created some sun shadow volumes from a building, but now I would like to know for instance how much percent of the day a point catches shadow. Is there a tool in ArcScene to calculate  that?
Patrick
Tags (1)
Patrickvan_den_Ende
Another problem that I've got is when I execute a sun shadow volume the shadow volume is going through other buildings. Is there a solution to cast the shadow on the ground and the other buildings instead of going right through it?
Patrick
NathanStocker
Hi Patrick, I have the same question - did you find an answer or solution to this problem?
Thanks
Nathan
SheebaSbeen
hi
I am having the same issue using ArcGIS Pro,the shadow of the building is not touches the building boundary. its some where in the air. Seems its assuming the building any where else.... Please suggest how to solve this issue???
YingYeung
Hi, I am doing a project that create the shadow from a 3D building model.
Therefore, I also want to know is there any tool used for analyzing how much percent or time that a point or a area catch shadow.
Thanks.
Ying
