Someone help me, please!
3810
6
11-14-2014 11:34 PM
DucMai_Chi
Hi, I have a problem when I create TIN in ArcGIS 10.2, it's always failed and I don't why.
Thanks!
DanPatterson_Retired
well I hope you values in the Val field aren't all 0.  Go to the Geoprocessing Results menu and expand the last process where you had the error and read the message, it should provide more details
many reasons...post the error message and what you are using to create and where you are saving it (ie to disk or to a gdb)
DucMai_Chi
I want to create a DEM from contours but I can't.
DucMai_Chi
DucMai_Chi
Just some values in that field are 0, most of them aren't 0.
DucMai_Chi
Thank you, Patterson. I created it successfully.
