Raster to Polygon conversion - showing error
6144
02-05-2014 08:48 PM
VikasRanga
Hi all,
To convert from Raster to Polygon, I am using "Toolbox --> Conversion tools --> From Raster --> Raster to Polygon". Input image (Image.JPG) is also attached with this post. Following error is showing, snapshot (Error.JPG) is also attached:
  • ExecuteError: ERROR 010328: Syntax error at or near symbol SPACE.
  • ERROR 010267: Syntax error in parsing grid expression.
Waiting for solutions. Need urgent.
Regards
Vikas
Tags (1)
by Anonymous User
Not applicable
Original User: WGustafson
Try a path for output that contains no spaces (\object based classification\ to \obc\). might be a syntax holdover from the unix workstation days.
Sincerely,
Will
Hi all,
Regards
Vikas
by Anonymous User
Not applicable
Sincerely,
Will
Hi all,
Regards
Vikas
HILLARYHALL
If the aboved solution cannot work, try to convert the your image to polygon by using a standalone raster image converter which suppports to render and convert raster image to polygon. If it works, check out your raster images, while if it neither works, try to get help from some pros.
