Problem converting TIN to raster
1099
09-26-2013 09:49 AM
adamzucker
I am a fairly new ArcGIS user and I am having a problem. A worker of mine created some TIN files that I have been using with GIS. They work fine in Arcmap. I was having intense lag in ArcScene while trying to view the TIN files, so I started converted it to a raster and it increased the speed drastically. I have successfully converted a few TIN files to raster without a hitch, however I have ran across a problem. I am trying to convert a vertical wall into a raster, but when I use the conversion tool, it converts only the flat terrain. No Z data is getting converted. I am not sure if the wall that I am trying to convert is just to thin or what the problem may be. Any help would be greatly appreciated. I am attaching the TIN I am trying to convert. Thank you.
adamzucker
FIXED..I was able to find a work around to the solution by just adding a polygon to the original TIN and extruding it in ArcScene to give the appearance of the wall.
