Point aspect from TIN
5241
08-15-2014 07:11 AM
CamillaRootes
I have a shapefile containing a series of points and would like to know the surface aspect at these locations. I have a TIN DEM and I want to extract aspect values from the TIN into the points' attribute table. I know that this is possible for raster DEMs (https://community.esri.com/message/37161?sr=search&searchId=2a454f81-4783-4cf7-948d-0924398ee4b4&sea...) but I haven't been able to find a way to extract this information from a TIN
Can anyone advise me on how to get the TIN aspect at my points? I am using Arc 10.1 with the basic license.
Thanks
RiyasDeen
You will need 3D analyst licence for this.
  1. Use Surface Aspect tool to create polygon FC with Aspect values ArcGIS Help 10.1
  2. Use Intersect tool to intersect your point features with Aspect polygon.
  3. Export as table using Table to Table tool
RiyasDeen
CamillaRootes
One thing I have noticed using this technique is that it only works with the Aspect code. Creating the TIN surface aspect layer converst the TIN triangles' aspect values into aspect code. Using the intersect tool then assigns an aspect code to each of my sample points.
It would be better to have the raw aspect value for the sample points. Do you know a way of getting the 'raw' aspect value rather than the aspect code?
RiyasDeen
On thing that quickly pops up is, you can create a Class Breaks Table for every degree value containing 360 rows or every half degree containing 720 rows, depending on your accuracy requirement.
will post back if I can think of something else.
CamillaRootes
Yes I'd been considering that, was just wondering if there was a more elegant solution! But I can always use the class breaks idea if we can't think of anything else.
CamillaRootes
I do have a 3D analyst license and have given this method a go - it seems to work just fine. Thanks for your help!
