Please can someone tell me the simplest way to import a rhino file (.3dm) into ArcGIS
3212
08-04-2016 02:36 PM
ChristopherDrew
I have a set of rhino files that I want to open in ArcGIS 10.3.1 desktop. How do I
Tags (3)
DanPatterson_Retired
FME comes to mind as a first check or can you export to dxf? most movement references on the web seem to be exporting to dxf, then bringing into a gis
BruceHarold
Rhino support is still in Safe's knowledge/ideas bucket, not implemented yet, you could vote it up.
So that leaves having the ability to export ... I saw some vague reference to python module which I will check
Edit
It seems to be for using python within rhino3d
