LAS file into TIN failed
4539
01-09-2016 10:45 AM
StanislavaV
hello friends, i imported las file into arcgis - looks like this...
can somebody help me with that please? thank you so much...
DanPatterson_Retired
move to 3D this is the lounge GeoNet Community Structure  and you will have a better chance in getting your question there
dump the points in the pointy section or window it, or mask it, otherwise the tin is the correct intpretation of the points LAS Dataset To TIN—Help | ArcGIS for Desktop
StanislavaV
that´s wonderful! thank you so much
