Is it possible to import large file (osm) in Cityengine 2015 ?
3393
01-02-2016 11:10 AM
reitsined
With the 2015 release, imports openstreetmap (OSM) seem limited to a certain size. In older versions of CityEngine it was possible to import large files OSM (about 700 megabytes). For example, I could import the city of Paris (France) complete ... today this no longer seems possible.
Is there a solution that I would not have found these to import large files?
Thank you and my best wishes for this new year.
DanPatterson_Retired
are you importing the same file? are you talking about the 2015 release of which one? CE or OSM? Were there any changes noted in the updates?
reitsined
Thank you very much for that so fast.
I do not know if openstreetmap modifies its files over time. Today with CityEngine 2015.0 I can import a quarter of the city of Paris. (Previously it was possible to import the city of Paris in one osm file). Otherwise CityEngine freeze and it does not work ...
Well OSM would be the place to check to see if the data are the same...if you have a legacy copy, then you can compare.
reitsined
I'll try to find my old OSM file to import it into CityEngine 2015 ... I will come back to say what it is ... Good evening
