Intersection of a DEM and a plane to extrapolate a geological fault
4363
08-01-2011 11:20 PM
lucasMesalles
Hello everyone,
I am currently doing a geological map and, based on my field collected fault orientations data points, I would like to infer the extension of the fault in other directions. Said in other words, I would like to create a plane of a certain orientation and being able to extract (i.e. create a feature) the intersecting line with the DEM.
So, I guess, the first step may be, creating the (fault) plane, then position it where my data point was collected, and finally somehow extract the intersecting line.
Could someone give me a hint? I know many geologist are using ArcGIS so I imagine other people may have faced the same problem.
Until now, I have being doing that manually, with classical mapping technics (i.e. triangulation), but I have recently started using ArcGIS, and I am sure there is a less time consuming way to do it.
Thank you in advance for your help and time,
Lucas
Tags (1)
JeffreySwain
Based on your description there are two tools that come to mind.  The Intersect 3d tool and the Intersect 3d Line with Multipatch.  I am not sure if that will create what you are looking for, but it may get you started.
You can create a multipatch of your surface with the Interpolate Polygon to Multipatch tool.
lucasMesalles
Thanks Jeff, I'm trying to explore this tools and see what comes out.
Just to clarify what my aim is: extract the surface trace of a geological fault from the intersection of a plane and topography.
NigelBaker
i have the same issue.
also a geologist and looking to find the intersection of a 3d plane (bedding plane with known dip/strike) with a 3d surface.
why is there no tool for this? it seems like a common geologist problem to extrapolate the expected outcrop of a particular unit?
i can make a 3d polygon, or multipatch polygon from a known outcrop trace.
i have a 3d raster dem, also TIN surface.
i cannot find a tool within ArcPro that can interpolate the intersection betweeen the 2 features.
