importing .LAS datasets (LIDAR)
5816
11-20-2012 10:17 AM
DavidO_Connor
I have a number of .LAS files, but ArcMap is not seeing them when I go to add them.  The file type (in the normal windows view)
shows it to be the .las extension but type  'DWG TrueView Layer State'.  This is my work laptop and I also have TrueView, and I think somehow TrueView added the association.  I downloaded the files from opentopography.org
How can I change the file type or add it into ArcMap?
Thank you!
Tags (1)
EricRice
Esri Alum
ArcMap doesn't support .las directly for display.  You have to create a LAS Dataset, then load the .las files into it (using references), then add the LAS Dataset (.lasd file) to ArcMap.  Optionally, you can load the .las files into a Mosaic Dataset and add it to ArcMap.
See Using lidar in ArcGIS, What is a LAS Dataset, and Adding lidar data to a mosaic dataset
Best,
Eric
