identify tool and profile graph
2524
08-23-2012 03:36 PM
JavierLeon
Since using 10.1, I have not been able to use the identify tool with profile graphs (...marker displaying on map when identifying a point on the profile graph). It used to work with 10.
Is this a bug in 10.1? Anyone having the same issue?
cheers,
Javier
Tags (1)
JeffreySwain
Are you right clicking and select 'Identify'?  It works fine that way for me?  Or are you trying to just use the identify tool?  When I right click the profile graph, select Identify then I see cross hairs on the location on the line.
StephenIrving
I too have encountered this problem since 'upgrading' to 10.1.  The tool behaved normally in 10.0, but now it does not consistently identify from the profile.  It seems to work best on steep portions of the profile.  Selecting profile segments is also spotty.  I get the problem both from 3d line features and from graphic line interpolations.
JeffreySwain
I would recommend creating a Support Incident to take a look at your setup. I have tried it with different datasets and different slopes and it works fine for me.  Open the profile graph, right click the line, select the 'Identify' and then for me a green dot appears while the cross hairs are drawn, the identify window also appears.
