How to use tool "Sun Shadow Volume"
9982
13
01-21-2015 06:17 PM
Syamsuri_Satria
Hello...i have problems about using tool "Sun Shadow Volume" In ArcScene 10.1.
i use feature (shp) extruded 3D layer
then i use tool "Sun Shadow Volume" with data :
     - Start date and time : 1/22/2015 6:00:00 AM
     - End date and time : 1/22/2015 5:00:00 PM
     - Iteration interval (optional) : 1
     - Iteration unit (optional) : hours
but always it don't succeed..
Thank You.
Syamsuri_Satria
Hi. Mr. Kishor Ghatage
<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK4-2FGLWVQ1uH8WI8E0R8ibgcuIG7nlQ6K3UrAI2u2MG3MX1kE6WduzsGXQEv5teQZLNk-3D_eDTyoq4gcI2sthplpZMwqm4VqzJdyfqOeajQI9nHwnh5S-2Byqw9Hx8XoB4ANbqrLYG1xKU-2FzhMgD0DvFd70TbzZXWGobfxdC1ddllDlAntYc2fscaU94NUkaEc5ybtnDo3Z72wQxVXUk7nfysXhLsye-2F-2FSU-2B-2B-2F5MEq1-2BUGwp3v3CLs-2Bw9xAgcGi7vx3w53ODJ-2B2rh6foAL4R-2Fox-2BA9o-2FvQk4GdtZ7Fwg8HAUSTSgWxrDlN9p1rlbI2ALiKb9l3Vd16P-2Fu6aNAsQszQK6tj-2BmSLavTBZDv8J6XJuuAPvBavJ3Vm41Y5As-2BQp4zdvd-2F-2B4mlyge8TjQuVeTSYz4LJXhoew-3D-3D>
thanks for helping me
this my file is multipatch feature for testing.
Zona Time (UTC+07:00) Bangkok, Hanoi, Jakarta
Thanks for All.
KishorGhatage
I tested the behavior using provide data. After defining the coordinate system tool worked as expected.  Please define the correct projection of your data and run sun shadow volume tool.
Steps:
1. Open ArcCatalog window / ArcCatalog
2. Navigate to multipatch feature class > Right click > properties > XY Cordinate sytem
3. Choose appropriate Projected Coordinate system > Click Ok
4. Use Sun Shadow Volume tool.
StephenKnox1
Fixed it by defining the projection of the data. Better error messages would be go though please ESRI.
Stephen
YingYeung
Finally, I was created the shadow successfully but I do not understand the meaning of "iteration interval" and "iteration unit".
Can anyone explain it? Thanks a lot!!!!
