How to create 3D solid geologic model of subsurface
4209
06-14-2010 10:03 AM
MinaRahimi
Hi everyone,
I have a dataset which have x,y,z of each point. In other words, base on these data I have the the thickness of different geologic layers. I want to create solid geologic map in 3D in ArcGIS.
I tried to install "BlockDiagram" from the link below, but I could not. Does anyone know how can I install this extension.
http://arcscripts.esri.com/details.asp?dbid=12632
Please help me if anyone knows other ways to create 3D solid geologic map.
Mina
Tags (1)
JakubSisak
Honored Contributor
Hi everyone,
Mina
This is normally done by extruding between 2 surfaces which created a multipatch geological layer. You will need 2 TIN surfaces (top surface and bottom surface) and a polygon layer containing input features that defines the area you wish to extrude.
See Toolbox -> 3D Analyst Tools -> TIN Surface -> Extrude Between
MinaRahimi
Thank you for your reply.
I do that and it just works for surface layer. For subsurface layers this methods creates the output that is not correct. I used bedrock geology as a polygon feature class for "extrude between".
Do you know how I can resolve this problem?
Mina
