Extrude between error - "A polygon part has no defined Zs."
6081
7
10-31-2011 01:42 AM
VictorKlinkenberg
Hi everyone,
I'm trying to create some multipatches by extruding polygons between two tin's (extrude between). i have a collection of tin's and polygons, with some polygon-tin combination this works no problem but with others I get the following error message:
ERROR 999999: Error executing function.
A polygon part has no defined zs.
Failed to execute (ExtrudeBetween).
I have tried to find out what this means but I can't find anything on this error ("no defined Zs"). I'm sure I'm doing something stupid but I can't seem to find the answer to this issue... Can anyone help me with this?
thanks a lot
Victor
Tags (1)
HenrySaddington
afraid I don't have an answer to this but I have encountered a very similar issue, i am just mapping out some different land uses using polygons and upon finishing drawing the boundary of my latest area I am presented with the error 'Failed to create (my layer) a polygon part has no defined zs.'
really not sure why this is happening considering iv just created a good 50+ polygons within this layer already today. feel it is worth mentioning that I don't have the 3d package of arc pro so even more unsure why I am getting an error about this.
posting this in the hopes of getting a resolution at some point
OznurGeze
Hi
Did you have an update in this topic? I have the same issue.
MarieLandis1
One of our users got this error while editing a polygon feature. This thread is the only documentation of the error that I can find, other than the developer site, which doesn't explain what the error means or how to fix it: esriGeometryError Constants | ArcGIS Enterprise SDK
ArcGIS Pro 3.3.1
User was creating a new feature in a polygon feature class in a file geodatabase using the Trace tool. Z values are disabled for the feature class. The feature class participates in topology. User got this error several times upon finishing the trace. Other methods of creating new polygon features never resulted in this error, and the error didn't occur every time trace was used, but only when trace was used. The trace drawing was snapping to itself, not another feature.
Snip from layer source:
Esri, can you tell us anything else about this error?
jmcewen_ddg
Did you try creating a random polygon with 3 vertices (click-click-finish) to recreate the error? I did that and it was fine, then went back to tracing to create the new feature. I traced half the feature, then the other half with no errors and then merged the two.
Had same thing happen twice on a separate brand new FCs that I unchecked the Z-values box for when I created it. Went to trace a line to create polygon and got the error. Tried again and didn't work. Might have something to do with vertices/lines that coincide for the same feature when it is created. That's just speculation.
NateButtermore
I got the same error while trying to trace. Instead of finishing the sketch with the Trace tool still active, I selected the Line tool, created a vertex or two located outside of the feature I was tracing, and then finished my sketch and it was fine. Then I just went back and deleted the 2 vertices I didn't like.
DavidlMason
I have the same problem with a mask layer I made by cutting out two countries from a large rectangle. Whenever I try to edit the vertices I get this error. I've repaired the geometry, but it didn't work...
Åshild_L
I experienced this error message when finishing the trace sketch before I created an endpoint for the sketch. The sketch needed to be showing the vertices before right-click Finish or F2:
Best regards,
Åshild
Support Manager Geodata AS, Norway
