elevation differences between DTMs
8550
14
05-31-2016 10:47 AM
StanislavaV
Hello friends,
i have two DTMs and two DSMs created from LAS files......
first LAS files were created in autumn
second LAS were created in spring
when i compare elevations between DTM autumn and DTM spring.......differences are minimal, but to and fro are big differences, like -50 metres
same at DSMs..
what could have caused it? may it be caused by noise by scanning or even something else?
thank you so much
DanPatterson_Retired
So it is 0.5 meters... well that is a whole lot different that 50 meters.
A lot can happen to give rise to a 50 cm = 0.5 m difference in elevation between the fall and winter in an area.
A pile of dirt, a dug hole, error, the list goes on
You will have to elaborate on the area a bit more and perhaps show a map of the elevations and their differences
SteveLynch
I understand the problem to be as follows. We have two rasters each with a cell size of 0.5 meters and when subtracting them from each other we see differences of 50 meters.
StanislavaV
Yes it agrees. These big deviations are only 1% of whole raster.
JodieParkes1
Hello - I was wondering what process you took to compare two DTMs?
Cheers,
Jodie
StanislavaV
hi Jodie,
i used Minus.
