DEM in ArcGlobe 10 seems not right, is it a bug?
1210
05-16-2011 06:54 PM
SongWendong
I have a model of pylon stands on a DEM in ArcGlobe 10. The place where it stands is a kind of slope, at least it is what I see in ArcGlobe. The higher ground is 3.5008 meters high, the lower ground is 3.49. The difference is only 0.01m.
I cannot believe what I see. There should not be a slope at all.
So I set the vertical Exaggeration in GLobe Properties. I choose globe surface to 10x exaggeration. Then I measure Height difference, the result is 10 meters.
That means the default none exaggeration is 100 times exaggeration.
Have you guys encountered this kind of problem?
Tags (1)
