Creating a 3D representation of soil layer?
2557
01-13-2014 03:55 AM
808707
Hello,
I was wondering if anyone could tell me the best way to go about this?
I have a DEM and a series of points which relate to soil depths collected during a field survey.
I can use interpolation to model the soil depths and end up with a depth surface.
What I then want to do is to lay the soil depth surface under the DEM and create a 3D model of the soil layer.
Thanks for any help!
Tags (1)
larryzhang1
Just for reference:
From DEM, derive raster surface first (and then laid over DEM) in ArcScene;
For soil layers, first build TIN data models/ TIN layer, which should separately represent the top and the bottom in each location (assumed xy having no change, only z changes).
[INDENT]Mostly, those subsurface GIS data are interpreted on geological, petrophysical, and geophysical properties, which come from logs /cores in boreholes, seismic or gravity surveying;[/INDENT]
And then conduct interpolation & analysis of TIN in ArcScene;
Modify and re-tune the 3D model as needed.
