Creating a 3D polygon from points with a Z value
9580
12-26-2012 01:44 PM
by Anonymous User
Not applicable
Original User: SStrand
I hope what I am about to ask makes sense. It is hard to explain without having an example to show...
I have a set of points with X Y and Z values and my goal is to convert them into a single 3D polygon shape which would envelop all of them. This is part of my Masters work and I am trying to use the points as a way to create a 3D object which represents the extremes within which other points can be created (in future tests).
Is there a way to create a 3D polygon directly with a tool? Or is there a round about way where I could convert the points to a TIN and then have it so generalized that it would only look at the outer most points?
Any help would be much appreciated.
Tags (1)
by Anonymous User
Not applicable
Original User: jkowalczyk
Is this http://www.cse.unsw.edu.au/~lambert/java/3d/ what you need?
Jarek
by Anonymous User
Not applicable
Yes! That shows the end result I am looking for from the points. Granted I don't need to visualize the growth of the polygon like this shows, but the end result where the polygon is enveloping all of the points is perfect.
by Anonymous User
Not applicable
Did you ever get this to work?! Looking for an answer to the same question.
-Dan
by Anonymous User
Not applicable
-Dan
Hey Dan,
Yes and no...I've got something that works but it isn't perfect. Here are the steps I am taking:
1. Collect point data with X,Y,Z data
2. Manually select points on the top end of the desired shape and create separate feature
3. Manually select points on the bottom end of the desired shape and create separate feature
4. Create TIN files for each feature
5. Use the 3D Analyst tool "Extrude Between" with the two tins to create a 3D polygon of the area between the two TIN files.
For me this is the best I could do. It gives a more generalized version of the data than what I was looking for, it does take a few minutes to create and it is something that I cannot fully automate 😞
www.spatialstage.com/VisualizingMotorsport.pdf
The above link is a presentation I did based on my thesis, in it there is a slide (pg 18) showing the 3D polygon that is created. Since the presentation I have cleaned up the way I visualize it which helps a lot, but that'll at least give you a look at the basic version of what I have made. Hope it helps!
Steve
by Anonymous User
Not applicable
Thanks for the help, i will give it a go!
-Dan
