Create points along a Z-polyline at distances listed in a table
2852
11-15-2010 12:25 PM
JeffPickles
I have a Z-polyline and a list of distances along that line that I need to place points. Is there a tool similar to Construct Points that will consider the Z distance in its calculations? When I try manually with Construct Points, it only considers XY distance and thus the results aren't accurate.
Also, is there a way to automate the process so that I can delineate the table field that contains point distances from the beginning line vertex and have the results be the series of points along that line? I'm looking at around 120 points to create so it'd be nice to solve that issue as well.
