Create Cross Section with Contour lines
15648
03-14-2013 11:54 AM
WinnieLau
I need to create a 2-D cross section with contour.  Anybody know how to do that?  I have 3-D Analyst.
Thanks!
Winnie
CarrieDavis
Hi Winnie,
You could use the 3D Toolbar to create a profile graph of the elevation along your contour.
Fundamentals of creating profile graphs
http://resources.arcgis.com/en/help/main/10.1/index.html#//00q800000071000000
First you would need to interpolate your contours into a 3D surface.
TopoToRaster
http://resources.arcgis.com/en/help/main/10.1/index.html#//00q90000000s000000
Add the newly created elevation surface to a map document and either use the Interpolate Line tool on the 3D Analyst toolbar to trace your area of interest.
myname
You create TIN from contours lines, then create cross section from TIN
Here clip for you : Create Cross Section with Contour lines - YouTube
