Converting a TIN to a shapefile
6984
09-12-2011 01:33 PM
chriscoulter
Is there a method or tool I can use to convert a TIN i have created into a shapefile?
Tags (1)
AndrewRaal
Hi -Not sure what you are after, I would convert the TIN to a raster then the raster to a shape �??point' file with the points giving elevations or whatever the TIN is representing.
JeffreySwain
It depends on the shapefile you are looking for.  You can harvest the nodes, edges, domain or TIN Triangles.  It just depends on what you are trying to achieve.  Otherwise the raster will best represent the surface if contour generation is what is desired.
FredericVidem
I'm trying to achieve a surface that is not so angular. More like the a tin in arcscene (see ex).
