ArcScene - Vector lines showing behind the raster
4310
08-20-2014 01:33 PM
JenniferDick
Hello,
I've added a DEM to ArcScene and now wish to add some vector data to overlay on it. I.e. boundaries, roads, etc.
However, when I add the vector data it appears underneath the raster DEM. I've changed settings in the base Heights tab and extrusion on the layer properties, as well as vertical exaggeration in the scene properties.
However, the layer still appears underneath.
How do I fix this problem, am I missing any steps?
Thanks
Jennifer
NeilAyres
When you first add the vector features into the scene, it will appear underneath (unless they're Z enabled).
In the base heights tab, you have to tick on the float on surface and chose your dem raster.
Sometimes because of rendering you add a slight offset to the vectors to make them appear slightly above the dem to make them fully visible.
Good luck,
Neil
XanderBakker
Esri Esteemed Contributor
There can be several reason for a feature to appear beneath a raster surface. You can have a look at the priority of the drawing order: About layer drawing priority in 3D
It might be that the 3D features are at the same height or a little lower than the surface. You can increment the z-value of the feature just a little to drape it over the surface: About defining the z-value for a layer
Some more information can be found here: About setting the role of a 3D layer in ArcScene
Kind regards, Xander
