ArcScene Initializing Problem
4016
8
02-26-2019 07:48 PM
AaronRussell1
ArcScene 10.6.1 won't initialize? How can I reinstall just this app?
DanPatterson_Retired
I think you might want to try a 'repair'.  Windows control Panel, Add Remove Programs, select 'Repair'
It might work to fix things without a full uninstall/reinstall
AaronRussell1
Still isn't working. Is a full reinstall my only other option?
So you have the 3D analyst extension toggled on (for ArcMap) and you have 3D data or data that you can view in 3D selected?
Is it hanging or it isn't available to select? Not sure what you now mean by initializing
AaronRussell1
It's stuck on the splash screen at " Initializing Application."
haven't had to roll this out in a while, but worth a shot
https://community.esri.com/docs/DOC-2121-resetting-your-arcgis-application-profile
AaronRussell1
Hmm, that hasn’t worked either.
Sent from Mail for Windows 10
AaronRussell1
Well, after uninstalling and reinstalling my problem has not yet been solved.
1.Start ArcScene
2.Splash screen pops up
3. Says "Initializing Licence"
4.ArcScene window opens as all white named "Untitled"
5.Splash screen remains open.
6.Splash screen says "Initializing Application..."
7.ArcScene then says "Not responding"
Contact Tech Support, something is amiss with your system and you will probably need to provide more information
