3D marker symbol causes ArcScene to crash
5872
13
04-02-2010 06:46 AM
HeidiLeighton
I had posted this in the old forum as I didn't know there was this new system. My apologies for cross-posting.
I have created a scene in ArcScene. When I try to apply a 3D marker symbol to a point shapefile in my scene, the program crashes with this error message: "ArcGIS Desktop has encountered a serious application error and is unable to continue."
My scene has three layers only:
1. A point shapefile with one point
2. a TIN of seabed elevation data
3. a raster of land elevation
I am trying to symbolize my point with as a 3D marker with a .3ds file.
I have tried creating a whole new scene several times with no success. I have increased the size of my virtual memory with no success.
Does anyone have any suggestions to fix this problem? I am supposed to be creating an animation for a client but I can 't get beyond this problem.
Thanks!
Heidi Leighton
Tags (1)
KarenZwicker
Heidi,
Thanks for posting this issue you're experiencing.
Do you mind sharing the actual files you are using and indicating which version you have?
I am currently unable to reproduce but it would help to recreate using your data.
Thank you
Karen
3D-Team
KarenZwicker
Hi Heidi,
To be more clear, sharing the actual 3DS file would be the best.
Karen
HeidiLeighton
Thanks for replying.  I would love to share the .3ds file with you but I can't figure out how to attach it. Can you advise?
Heidi
KhalidDuri1
Hello Heidi,
Attachments can be uploaded by clicking the Manage Attachments option that displays beneath the New Post dialog. Here's the relevant information from the FAQ:
How do I attach a file to a post?
To attach a file to your post, you need to be using the main 'New Post' or 'New Thread' page and not 'Quick Reply'. To use the main 'New Post' page, click the 'Post Reply' button in the relevant thread.
On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page.
To upload a file from your computer, click the 'Browse' button and locate the file. To upload a file from another URL, enter the full URL for the file in the second box on this page. Once you have completed one of the boxes, click 'Upload'.
Once the upload is completed the file name will appear below the input boxes in this window. You can then close the window to return to the new post screen.
What files types can I use? How large can attachments be?
In the attachment window you will find a list of the allowed file types and their maximum sizes. Files that are larger than these sizes will be rejected. There may also be an overall quota limit to the number of attachments you can post to the board.
HeidiLeighton
Here is a zipped file of the .3ds I am trying to use as a marker symbol.
Heidi Leighton
KarenZwicker
Hi Heidi,
Thank you for supplying the .3ds. However, we were unable to reproduce the crash you were experiencing, in-house. We tried on many points as well.
I have a few more questions for you which may help us figure out whats going on.
(1). Are you still testing on Beta? Or have you updated to the Pre-Release version which is now available?
(2). Is the model textured (uses many images draped on the 3DS geometry)?  If so those files were not attached - so could be why we could not totally reproduce your issue.
Karen
3D-Team
HeidiLeighton
Thanks for your response.
I am using ArcGIS 9.3.1 with an ArcView license. I have the 3D Analyst obviously, as I have been trying to develop a 3D scene. The software is installed on a machine running Vista (64 bit version) - this may or may not be important.
The .3ds model I ma using doesn't have any textures.
Heidi
JakubSisak
Honored Contributor
Which application did you use to create the .3ds model? As for 64bit version, i believe that officially it is supported (will run) although ArcGIS gains no advantage as will only run at 32 bit, utilize a maximum of 2GB RAM and only one core if multi-core processor is used.
HeidiLeighton
I did not create the 3D model. I received the model from my client who asked me to insert it into the scene and run a fly through animation over it.
I have also tried bringing the model in as a .dae file. This file type also crashes ArcScene.
