3D Doc
6426
29
03-04-2010 02:57 PM
TedCronin
http://help.esri.com/en/arcgisdesktop/9.4/help/index.html#/A-quick-tour-of-3D-Analyst/00Q80000000300...
The 3D Effects toolbar
There should be some text to show what application that each toolbar belongs too.  I had to find the swipe tool, to determine this fact.  It would be nice to just have some sort of bold text stating this:
ArcGlobe:
ArcScene:
Tags (1)
KarenZwicker
Hi Ted,
Agreed, its not boldly obvious, but the content does state ArcGlobe and ArcScene in the order that the toolbars appear respectively. As well there is tool tip help so if you hover your pointer over the graphics, each toolbar is labelled as either the ArcGlobe 3D Effects toolbar, or the ArcScene 3D Effects toolbar.
The pointer tip help is true for all graphics. Its like a little pop-up caption.
Karen
KarenZwicker
Hi Ted,
I just updated this topic today with your request.  There are now headings above each toolbar.
Thanks for the suggestion!
-Karen
3d-Team
TedCronin
Cool, thank you.
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/What_is_editing_in_3D/00q80000003n000000...
When should you edit inside a 3D view?
Simple edits that you noticed while in the 3D view (such as editing attributesor moving points)
Should be:
attributes or
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/The_3D_Editor_toolbar/00q800000124000000...
3D Editor toolbar drop-down menu options
Is the Save Edits suppose to have a hyperlink?
BTW, I like the graphic detailing what can be used with each tool, on the 3D editing toolbar dropdown, this took some time to make this little graphic.
For the The 3D Editor toolbar tools
Edit Placement Tool and Edit Vertices do not have hyperlinks, too.
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/Combining_features_from_different_layers...
As part of Step 3
Click the 3D Editordrop-down menu and click Union.
Needs a space between Editor and drop
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/Rotating_a_feature_in_3D/00q80000003q000...
Step 3:
Access Rotate by doing one of the following:
Click3D Editor and clickRotate.
spaces-
Click 3D Editor and click Rotate.
TedCronin
It would be nice to have a page in the editing section for just Editing Shortcut Keys in relation to 3D Editing, something that we can get to quickly, I see the shortcuts in the doc, but they are a part of the read, and sometimes, you just want to see a list, perhaps there is a doc, and I just haven't found it yet, the day is still early.
TedCronin
http://help.esri.com/en/arcgisdesktop/10.0/help/index.html#/How_to_set_snapping_properties_in_3D/00q...
The snapping properties allow you to specify what part of the feature ( vertex, edge, or endpoint) you want your new feature to snap to
Space between "(" vertex, also sentence ends in to.
